nParticles Liquid Simulation will not work properly
Hello
I have made a model of a fishbowl and used nParticles then Modify Convert nParticles to Mesh to make water. When I hit play, the mesh falls outside of the passive collider fishbowl a little bit on the sides. I have enclosed pictures, any help would be appreciated. Thanks!!
m.kienmeyer
It looks like the bowl is one-sided. If that's the case, try modeling the inner side as well so that the mesh is solid/enclosed before making it a passive collider of the fluid.
Hope this helps.
mspeer
Hi!
Multiple Options:
1. Edit Output Mesh Properties.
2. Edit Particle Size and Collisions Parameters.
3. Add Thickness to your fishbowl, for the nRigidShape or/and for the mesh itself.
Thank you for your reply!
I'm not sure exactly what you mean by "one-sided," do you mind explaining?
I have tried changing all of those attributes, but the liquid mesh still goes outside of the polygon. Are there any other attributes that could be the source of the problem?
Hello everyone, I'm lonely 1scasino
mspeer
Hi!
Please upload your scene-file.
