nCloth properties
nCloth properties
Message 1 of 1
nCloth properties
Hello everybody, i`m making a project with dynamics, active rigid bodies,with movement and I added a ncloth object which covered them but not in the moment I need. Is possible to modify the entrance frame of this object, for example, it will be great if it appear on the 200 frame, when the action is almost ending instead of the frame 1. I´ve tried putting the ncloth object more to the top but then it appears on the scene with more gravity and slide to a side so it doesn´t cover up well the dynamics objects.
Thanks a lot
Replies (0)
