Announcements
ncloth not moving with object
mgr0704
mgr0704
Don't use nCloth very often. Trying to get a flag attached to a pole to move with the pole. Followed several tutorials and they all say the same thing: select vertices of nCloth, shift select pole, under nConstraint select point to surface. All good, hit play, flag sticks to pole, wonderful, but I want to animate the pole with the flag stuck on it, and when I move the pole, the flag does not follow. What am I missing here?
sepu6
Is working fine here Maya 2022.2
 I did not change anything in your scene I just animated the pole.
mgr0704
Well, I'm an idiot. I just moved the pole around and saw the flag did not follow. Never actually played it back so the simulation could build. Thanks.
