MASH animation curves
cptchris040
cptchris040
How do you control the animation curves for automatically animated things? For example. I apply a simple offset to a distribution of cubes. I add a falloff so the cubes move to the offset position as the volume touches the cubes. How do I change the curve on the cubes so when they are offsetting it is a slow in/slow out, or a fast out/slow in? Is there a place to get to that curve?
Roland.Reyer
I'm not sure if I understand your question.
You can define the transition between outside the falloff object and the inner zone with the value "Inner Zone".
There is also a falloff curve that defines the transition.
cptchris040
No...what I mean...and hopefully this makes sense. There must be a curve somewhere defining the animation of an object moving to it's falloff position from it's initial position/state. Does that make sense? How or where do I control that curve?
Roland.Reyer
Aren't the objects moving in a straight line?
Can you show us an image?
cptchris040
It was the falloff ramp I was looking for. I got it. However, without bezier handles this is really limiting!
Why is it none of these have bezier handles? None of them do. Even the ones in the HyperShade. How do you control the incline of the ramp?
hoganburrows
Change in interpolation from linear to smooth
