Magnetic Field Effects
darioOrtisi
darioOrtisi
Hello.
I was wondering if anyone is able to reproduce this effect with Maya.
It would be great an advice.
Houdini effects: https://www.youtube.com/watch?v=ExUbAuK0B-s
sean.heasley
Hi @darioOrtisi
This tutorial doesn't achieve the exact results of that Houdini video but it should help get you started!
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
darioOrtisi
Thank you, but ithis is a very basic tutorial. I mean about an expression on particles where the p1 attracted by p2. I'm talking about some perparticles expression that create this effect.
sean.heasley
Hi @darioOrtisi
Ah ok that would require some really fancy work within Maya and/or scripting work which I can't provide for you since that's technically outside of technical support.
It's also worth noting that Maya and Houdini are very different programs and how one things is accomplished in Houdini may not be as simple to do in Maya and vice versa.
darioOrtisi
I'm share this tips from Peter shipkov of your SOUP plaugin for Maya and OpenVDB
http://www.soup-dev.com/?p=post%2Fmagnetic-field-9739661%3Ftrail%3D15%233
It's awesome.
