Fluid fountain
Fluid fountain
Fluid fountain
How can i create a fountain or fluid that gets shot out of something like a water gun or something like that?
i havent found something helpfull on youtube or else, so i need to ask here.
mspeer
Hi!
Just add an emitter to the object (for particles, fluids, or whatever you want to use).
i did already a fluid simulation, but its just floating from top to bottom but i need to shot them out of a pipe or something, but with bitfrost it just pours out
mspeer
Hi!
For fast movement you just need a higher value for speed, velocity, or whatever your simulation is based on.
Please read the Maya online help for information about the Attributes used for Emitters, Fields and Solvers.
InNeedOfHelp
If I'm understanding correctly, what you're looking for is a bifrost motion field. You can try just using the same object you're using for the emitter, selecting that and making it a motion field. This will basically give your fluid some initial velocity and then gravity will take over.
