Bifrost Scale / Units?
Hello everyone!
I am struggeling with understanding the scale and unit system of Bifrost. I read some forums and watched a lot of videos about it but I'm not really getting it, yet.
In most the videos, forums & documentations was said that Bifrost doesnt care at all about the linear Working Units in the Maya preferences because 1 unit will alway be 1 meter for bifrost.
If I have my Working Units in Maya preferences set to centimeters and I create a cube it has a scale of 1x1x1. From what I understand this means for bifrost 1 meter x 1 meter x 1 meter.
When I change the Working Units in Maya preferences of the same scene to meters and I create a second cube it is one hundred times bigger but it's scale is also 1 x 1 x 1. And I don't get how both cubes are 1 meter x 1 meter x 1 meter for bifrost.
So there must be at least some reasonable reference when creating objects. Beside messing around with the camera's clipping planes.
In a forum post someone said "Bifrost works best in the default unit of cm, but treat each unit as if it were 1m" (Source - The Area)
On the other hand Daryl Obert mentioned in the comments of this youtube video that he is always working in meters and never changing it.
In this tutorial Dave Scotland is workig with Working Units set to centimeters but since the bottle has the scale of 1 which would equal 1 meter for Bifrost he is scaling the bottle down to the scale of 0.30 which would be 30 centimeters to Bifrost.
Then again in this tutorial in the Maya Learning Channel the tutor refers to the Working Unit in the preferences as being in centimeters and therefor he is messing with the Bifrost settings to match them (setting Gravity Magnitude to 9.80 to 980 etc).
But if you open the scene files each of the buildings has a scale of 1 x 1 x 1 which might have happend by Freezing Transformations. The container has a scale of 0.413 x 0.413 x 0.399 and the emitter a scale of 34 x 4 x 65.
If I'd rescale (x100) the whole town to match the original Gravity Magnitude of 9.80 I get buildings with 100 x 100 x 100, a container with 41.3 x 41.3 x 39.9 and an emitter (which needs to be created first) of about 3419 x 628 x 6679 which means it would have an x and z scale of some kilometers within a container with the size of some meters?
I brought up everything I found about it and the issues I am having with understanding scale & units with Bifrost and I hope some people would look into it since it is very basic for the understanding of Bifrost.
Thank you and have a great time,
Alessandro
