Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Wire Tool/ Rigging Help
1 REPLY 1
645 Views, 1 Reply
I was following this tutorial on how to make a wire tool, as im trying to make a rig for a turret that can move its head and body seperatly, with a wire connecting the two. It works fine as long as its not moving, but i wanted to animate the entire turret moving and when i move the base parent joint video
What did I do wrong?
(Btw i work in meters here and boudning i set to 100, when bounding is 1 it moves fine but dosent rotate)
Labels (6)
1 REPLY 1
mcw0
You are getting a double transform on your cable.  Unparent the cable from the hierarchy.  Or turn off it's inheritsTransform.
