Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
What is happening here?
3 REPLIES 3
metalheadmortal
266 Views, 3 Replies
So i rigged my model and binded the skeleton with the mesh. When I move the arm this happens
3 REPLIES 3
in reply to: metalheadmortal
Have you painted any weights? If influence from your arm is affecting the waist area, it will move whenever you move your arm control.
metalheadmortal
I have Im not sure if I did it correctly here is the file
mspeer
Hi!
I recommend to go 1 step back (before bind skin).
1. Clean up your scene, you have hundreds of nodes of history on your main character, delete them.
Edit -> Delete By Type -> History
Also your default viewport cameras seem to be parented to another node ?
2. Read the following abound skin bind, including the following pages:
http://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=GUID-8DBA9E62-3854-4348-A0AD-1F981ECEA54F
There are also examples included that show the same user error, for example:
http://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=GUID-36890D37-174B-4952-8454-24CD95E47E1A
3. Try multiple skin bind methods and choose the one that leads to the best result. You may need to fine-tune your weighting further, for example
http://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=GUID-7D773C38-F9CF-4141-8ADD-4E0454838BB7
