Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Using IK Blend Keeps Crashing Maya 2020
5 REPLIES 5
tkr.k
476 Views, 5 Replies
When I use the IK Blend function, Maya 2020 stops working.
I just made a joint chain, made an IK handle and tried to use IK Blend.
I think it's a bug or dose anybody experience this too?
Case 1Case 1
Case 2Case 2
Tags (2)
5 REPLIES 5
kelly_hynes
in reply to: tkr.k
I'm not able to reproduce this.  Could you send a few more details.  Are you on 2020, or a 2020 update release?  What platform are you using (win, mac, linux)?  Also, do you have a CER number and/or call stack you could send me.
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
tkr.k
in reply to: kelly_hynes
I use Maya 2020.4 with Windows 10 Home.
I tested both Single-Chain and Rotate-Chain Solver and got the same issue.
My IK handle settings are set as a default(clicked "reset tool" and made the handle).
I noticed after I keyed an IK blend attribute, changing the attribute number by holding a middle mouse button and sliding left and right stopped working.
mspeer
in reply to: tkr.k
Hi!
I can't say anything about the crashing, but the middle mouse update issue in the Channel Box reminds me of a bug in Maya that should be fixed in Maya 2022.
Please try Evaluation Mode "DG" instead of "Parallel" or even better try Maya 2022.
tkr.k
in reply to: mspeer
Thanks for your input, @mspeer
I did set Evaluation Mode as Parallel while doing the test.
DG Mode seems working fine. I have encountered neither the IK blend bug nor the middle click issue.  It's a good workaround.
I tested the same scenario in DG and Parallel with Maya 2018 and there was no problem.
I say this is a bug. Parallel Evaluation has been a default since Maya 2016.
Do Autodesk intend to fix this or Maya 2020 bugs in general?
Or they focus on only Maya 2022 updates?
Could @kelly_hynes give me the answer?
mspeer
in reply to: tkr.k
Hi!
If I remember correct this was a bug introduced in a Maya 2020 update, maybe even it's only in Maya 2020.4, so you could try a previous Maya 2020 version.
I recommend to upgrade to Maya 2022, especially if there also other bugs in Maya 2020 that you want to have fixed. (Further updates for Maya 2020 are extremely unlikely.)
