Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
hello I'm having a problem with my maya 2023 I had been animating yesterday with no issues but today when I try to open the same file it just says that there are unsupported nodes and to check the script editor but when i try to do anything maya immediatley shuts down and closes so i dont even get to try and fix it...I have tried to open older autosave files but i get the same message.
I can use may 2022 as the rig that I am using wont work with any other version of maya other than 2023+
Solved by dinofiguera. Go to Solution.
It's saved as a .Mb file....would there be a way to change it because it doesn't stay open long enough for me to save it as anything else..I don't know if its because of the plug-ins i have because i use Animbot, JT Ghost, Studio Library and Dreamwall picker that came with the rig in the scene...I've tried to do the file -- optimise scene--- remove unsupported nodes but my maya closes before i can.
https://drive.google.com/file/d/1IuINWmdXk3RodnRPtDqwRRjY96MQzLmE/view?usp=drive_link
update: I uninstalled and reinstalled maya 2023 and set up a new scene and I think the unknown nodes is coming from the actual rig. I did the optimise scene tool and resaved as a .Ma file...but...when I try to use any 2 facial poses in studio library maya closes completely with no warning...I dont know what else to do
Try the following: 1) Switch parallel evaluation off and use DG instead in the animation preferences. Unload all plugins in the plugin manager and try to open the scene. 3) open a new blank scene, close all the Maya windows and editors, and import your problematic scene in it.
this sort of worked for me especially changing from Parrellel to DG but unloading the plugins I'm not sure stopped the crashing....thank you for the advice though
