Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Unsupported nodes maya 2023 maya shutdown immediately PLease Help!!!!!!!!!
5 REPLIES 5
tevin93
289 Views, 5 Replies
hello I'm having a problem with my maya 2023 I had been animating yesterday with no issues but today when I try to open the same file it just says that there are unsupported nodes and to check the script editor but when i try to do anything maya immediatley shuts down and closes so i dont even get to try and fix it...I have tried to open older autosave files but i get the same message.
I can use may 2022 as the rig that I am using wont work with any other version of maya other than 2023+
Labels (4)
5 REPLIES 5
damaggio
in reply to: tevin93
the scene is not attached.
tevin93
in reply to: damaggio
It's saved as a .Mb file....would there be a way to change it because it doesn't stay open long enough for me to save it as anything else..I don't know if its because of the plug-ins i have because i use Animbot, JT Ghost, Studio Library and Dreamwall picker that came with the rig in the scene...I've tried to do the file -- optimise scene--- remove unsupported nodes but my maya closes before i can.
https://drive.google.com/file/d/1IuINWmdXk3RodnRPtDqwRRjY96MQzLmE/view?usp=drive_link
tevin93
update: I uninstalled and reinstalled maya 2023 and set up a new scene and I think the unknown nodes is coming from the actual rig. I did the optimise scene tool and resaved as a .Ma file...but...when I try to use any 2 facial poses in studio library maya closes completely with no warning...I dont know what else to do
dinofiguera
Try the following:  1) Switch parallel evaluation off and use DG instead in the animation preferences.   Unload all plugins in the plugin manager and try to open the scene.  3) open a new blank scene, close all the Maya windows and editors, and import your problematic scene in it.
tevin93
in reply to: dinofiguera
this sort of worked for me especially changing from Parrellel to DG but unloading the plugins I'm not sure stopped the crashing....thank you for the advice though
