Maya Animation and Rigging
Welcome to Autodeskโ€™s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Two rigs driving same geometry part of ik chain
1 REPLY 1
Pagel.Lara
172 Views, 1 Reply
Hello!
I have this humanoid golem who is made of seperate stones that are to be driven by the base movement rig with fk/ik on the arms and so forth. I've been looking for a way to have these stones that make up the limbs have a seperate way to animate them gently floating around independently of the animation on the fk or ik controllers.
I technically have a way as i created a seperate disjointed set of joints i called FLOAT that are skinned to the stones and influence them just fine, but these new FLOAT controllers and joints wouldnt follow the main rig which would make it hard to animate. I tried to constrain the FLOAT groups to the driving rig but that just caused double translation on the mesh.
โ€ƒ
Any way I can solve this or do i just have to accept that the FLOAT rig will have to be... floating around behind the rig? Is there a better solution to what I'm trying to do? Thanks in advance ๐Ÿ™‚
Tags (1)
1 REPLY 1
mcw0
in reply to: Pagel.Lara
They are stones.  Do they need to be skinned?  Why not just have them in a group constrained to your joints.  Then use some noise function to move the stones within this group.  Particle instancing is another approach.
