Transform tools cause maya to crash
ID22OX22
ID22OX22
I've been having some problems with Maya for a while.
Sometimes, when I use the rotation or translation tool, it causes Maya to crash.
Is anyone else having this problem? Does anyone know how to fix it?
Please reply soon if you can help.
Replies (7)
gautham.chandran47
Is it crashing while you select either tool or use it on a mesh or controller?
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
ID22OX22
When I try to use it. You know. Move or rotate. Anything from joints to meshes.
gautham.chandran47
It's possible that if you're selecting and moving a mesh, that mesh might have an overwhelming amount of history nodes attached which causes memory issues and crashes. Is it possible to track your ram/cpu usage during these events?
Goutham Chandran
ID22OX22
I don't know.
If that's the case, is there a way to fix it?
gautham.chandran47
You can try a bunch of things,
• Delete non-deformer history from the mesh, if there's any
• Changing animation Evaluation mode to DG in the preference menu
• Switching viewport 2.0 rendering engine to DX11 ( or another option depending which GPU you have)
• Maybe even try updating your graphics drivers and delete Maya preference folder from documents.
Hope this helps!
Goutham Chandran
ID22OX22
Thanks! I think these methods worked!
gautham.chandran47
Glad it worked out. 😊
Goutham Chandran
