Time Editor Additive and Override feature for Clips not available?
I have tested out the Time Editor in maya 2018. What appears to be missing is the ability for the Clips themselves to have the Additive and Override functionalities. (Unfortunately, only layers created on top of the Clips can be set to additive and override.)
mspeer
Hi!
It seems you described the correct behavior of Time Editor (if i understand you correct).
If you have an idea for a new feature, use this:
Help -> Speak Back -> Ideas for Maya
Thanks for your response!
I'm having a little trouble accessing the path
Where exactly can I find this Help page if you don't mind me asking.
Btw, I found this 'Submit your Ideas' page:
https://forums.autodesk.com/t5/forums/postpage/choose-node/true?interaction_style=idea&catId=&boardI...
However, there is no Product drop down option for Maya, oddly enough.
Cheers.
mspeer
