Split keyframe tangents/curves
Giantrobo
Giantrobo
Hello, it would be great if someone could tell me what's going on. I am not Maya savvy. I'm using Maya 2012.
My tangents are separating into two points when I rotate a limb where I already have a key.
If I make a key from scratch and rotate, this split doesn't happen, it's only happening on older keys.
I don't know how I got here and I really want to unify the tangents/curves (not sure what to call this) back into a single point. I've tried Keys>Unify Tangents for instance and that's not it.
Splitting in two.Splitting in two.
jmreinhart
In that image the issue is not the curve tangents. You have two keys on the same frame (which can happen if you move keys in the graph editor incorrectly). Just delete one of the keys in the graph editor and the curve will become smooth again.
Giantrobo
Fantastic! Thank you so much, Jonah.
