Skin weights can't be seen/changed/exported
benjamindeutscher
benjamindeutscher
I can no longer paint skin weights on my model- nor can I see the skin weights or export them. I've tried on multiple maya scene files, but it will not let me do anything as far as editing or viewing skin weights. I tried exporting them so I could re-import them and try again, but Maya will not export them either.
When I attempt to paint the skin weights, nothing happens, but when I attempt to export them I get this:
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/exportSkinMap.mel line 287: Failed to export the attribute map. //
Replies (7)
Hi
I have attached the Ref images. Please refer your settings  in this same.
benjamindeutscher
I've attached what I have. Are you saying that specific skinning methods stop me from viewing the paint data?
Hi
Can you you share your scene file? we will see'
benjamindeutscher
Sure thing. Although the problem seems to persist with all versions of this file.
Hi
I attached your scene. check it
benjamindeutscher
Yes! Thank you. The weight painting seems to work now. What did you do to the scene?
Hi
Your Geometry  had history. so i cleaned  history then bind, problem Solved.
