Skin bind not binding
This widget could not be displayed.
I have my character bind with interative bind, and when I move the skeleton the skin or the character is not moving. I tested using cylinder and use 3 joint and bind with either smooth bind or interactive bind both of them are not moving the object, the joint skeleton is moving but the skin is not moving.
Can someone help me with this?
whisper1
Have you tried smooth bind?
Select vertexies and open up Componenet editor. One of the tabs should say something about smooth skins. On top will be a row with the names of the joints, with the values of the vertexies below. Does this show you any values?
