Hello! I hope I'm asking the question in the right place. My problem is that I made a model and I am trying to bind a skeleton on it. However, it doesn't seem to be binding at all. I'm not quite sure what to do. I used humanIK to help create a skeleton. Here's the project file if you need to take a look.
https://drive.google.com/file/d/1AnEZXrODxpx0LrhTO6bDYV47-zQgWrvi/view?usp=sharing
Hi!
No problem here.
Please add more details.
What tools, steps and settings are you using?
Do you get any error message?
Hi
I bind themodel with skelton. nothing error will come, its work fine. pls check , i attach the file.
huh, that is incredibly weird. Maybe it was just a small bug? Cause now I can bind it now. Basically what was happening before was nothing was happening when I was trying to bind the skeleton with the skin. I would press the bind skin option, even go through the settings of the bind skin thing, and nothing would happen. They were still separated and I thought I messed up in my rigging or something. I wonder why it suddenly changed?? Could be a small bug or something. Thank you for checking it out for me.
Thank you so much! For some reason, I can bind it now. Basically what was happening before was nothing was happening when I was trying to bind the skeleton with the skin. I would press the bind skin option, even go through the settings of the bind skin thing, and nothing would happen. They were still separated and I thought I messed up in my rigging or something. I wonder why it suddenly changed?? Could be a small bug or something. Thank you for checking it out for me. Sorry, this question is now a bit silly i guess
