Setting a Key frame for Object moving along Motion path
Richardd013
Richardd013
Hi !! im having a problem about animating an object that follows a motion path in Maya.
the keyframe im working is from 1 frame to frame 30.
So i attached an object to a curve that i made in maya  by going to the animaton tab > Constrain > Attach to Motion Path ,,
however with this feature im unable to control the keyframe / speed of the object that follows. the object is moving along the curve automatically start moving at frame 1 and stop moving at frame 30.
is there a way to key a frame manually while keeping the object constarined to the curve?  in that way i would be able to control the speed for each frame!
stephenkmann
yes,
 click on the motion path node in the channel box.
 and animate the U value
-=s
mustafa.burhan202
Observer
Observer
Hello, But I have a problem when I make a frame for the character or something, I can't then connect it to the path
