Hello Everyone, I'm looking for a python script or other method to set for each keyframes the xyz (transform and rotate) attributes in maya.
I need to solve this issue because I've a sensor data (9 axis) and it saves a csv file with all values. I would like to import these values in maya to study the movement using HumanIK.
Is there someone can help me to find a solution? Thanks
