Script job using the "timeChanged" event always executes...even when time hasn't changed
I have a bifrost setup that is using previous frame values to calculate velocities. I have conditionals to reset everything based on a startframe value. But even with that, I still need to kick the system with a "dgdirty" command. So I thought I'd use a scriptJob to run the "dgdirty" command for me whenever the current frame is less than or equal to my startframe. I save the file at my start frame.
When I reopen the file, the scriptJob is created and then it runs the "dgdirty" over and over again. Even though time has not changed. I was expecting it to run once only. Why is it running when time hasn't changed?
