Rigged clothing needs to be ripped off by a spinning object
whitneydigital
whitneydigital
I need to animate several layers of clothing getting ripped off a rigged character and then wrapping around a large rotating piece of machinery.  Is there a way to animated a piece of geo unbinding from a skeleton and then into a bend deformer?   If I could animate skin weights I could imagine having the geo "peel" off the rig, but I don't think there is a way to animate skin weights.  Any other ideas before I try a full-on cloth simulation which I expect to be an endless time pit.
mspeer
Hi!
skinCluster -> Deformer Attributes -> Envelope
bend -> Deformer Attributes -> Envelope
whitneydigital
Thank you. Pardon my ignorance, but I’m not sure where to find your suggestion in the menus. I see “cluster” in the deformers menu, and I see “smooth bind” in the skin menu which creates a skinCluster. But I cannot find envelope bend anywhere.
mspeer
Hi!
Check the Attributes of these nodes in Attribute Editor.
dinofiguera
Sometimes it is very handy to use the good old trick of show and hide.
I'm not sure how your scene looks like but what I do very often, instead of trying to change the rig is
to rig a separate copy of what I want to detach, and then show the new detached part and hide the original one in the right frame, in order for the animation to be seamless and smooth.
Cheers,
D
