re-enabling parent constraints after baking
I have an engine model rigged with FK and parent constraints which needs to be rendered via Backburner across multiple PC's. The only way to get the internal components to render without shaking/jittering/popping into position (the render nodes handling different frame ranges) is to bake the position/rotation of the geometries, which works fine. I need to go back and render an earlier frame range, prior to the range where I baked the geometry....and now all the parent constraints seem to be broken, even after deleting the geometry's baked keyframes. The bones and locators all animating as the should, but the geometries are no longer influenced by them....I see nothing obvious in any of the parent constraint attributes/channels...what am I missing? Thanks in advance!
