Problem with Paint Skin Weights
Hi everyone) I have a problem, I put weight to my joint, then, when I come back to this joint, I saw that weight spread on the other vertices, how to fix it? Even if I delete all weight of joint, after that I see that it still have some influence.
Hopefully you will get an answer to this question... I really stuggled with skin weights.  You should check out https://www.ngskintools.com.  It’s a great program with excellent tools for skin weights.
