Problem with corrective blendshape
Hello everyone
I have a problem with my corrective blendshape for fully opened jaw of my character's facial rig. I can translate left side of the face, but when I try to mirror it to the right side (shape editor > mirror target) it refuses to mirror it properly. I have tried to move vertices near the right mouth corner, but instead of translating particular vertex I have been affecting nearby one. Also when I am using shculpting tools like relax or smooth to affect this area it changes propoerly and then immediately changes into a mess.
Thanks for any help.
Please check your  model in Symetrical.
Do you mean turn off symmetry? It's turned off.   When I drag one vertex, other - one of the neighbouring is moving. And the problematic vertices are only those on the right side. Problem starts directly in the middle, and only after creating first corrective blendshape.
Hi
Can u share your scene file i will see
I think I may have found a solution for this particular problem. It seems that creating a new corrective blendshape with post-deformation order not pre-deformation - as I did before, make all vertices on the right side editable. Unfortunately other problem appeared - I can't do mirror target or flip target, but I can change other side manually. Regardless, I can consider this problem solved.
