Possible to always show vertex id's on unselected objects?
mostly_human
Message 1 of 1
mostly_human
Typically the vertex id's will only show on a selected object and as soon as you select a different object the id's will no longer show on the now unselected object.  Is there anyway to make it still show the id's even if the object is unselected? Also curious if its possible to show the vertex id's on a layer referenced object. Thank you for any help!
Replies (0)
