Creating a dynamic plant with three branches and many twigs.
method: Dynamic Curve with IK spline to drive bones
Branches, a single curve/spline work fine.
When I create the twigs individually (as if they were just more branches) and they are parented/linked to the main branch the system works fine but since each branch has it's own system there are no self-collisions, hence no interaction with the other twigs.
If I build the twigs all in one system the self collision works but the collision objects (the yellow visualisation) remain in the same location as the first frame - as in, the curves update but the collision doesn't.
Any suggestions much appreciated
Cam
So in a nutshell - collision does not update on dynamic objects that are parented to other dynamic objects.
