Need advice on IKFK switch
I`m new to rigging, but I followed a tutorial. Now I have a character with legs and a switch (an attribute) that can slide the weight between IK and FK control. Neat! And it works, or so I thought.
The rig breaks when I key the switch (to get a smood transition between IK and FK)
I made this Gif to illustrate the problem
As you can see in the gif, the switch works fine when manually scrubbing the attribute, but it breaks when the attribute is animated with keys.
This is all so strange to me, and I`m new to rigging. Any advice how to solve this?
(Setup: Switch attribute is connected to the "IK blend" of each IK handle. Each FK parent constraint node`s FK weight is connected to a reverse node, which in turn connects to the same Switch attribute.)
