Maya is not mirroring joints correctly
puchis5573
Observer
puchis5573
Observer
Observer
So I´ve been trying to mirror my leg, but for some reason it is mirroring weird.
The knee is too high and the foot is flipped. I don´t know if it is a mistake I made or if it is maya, I´m a student.
I will appreciate your help, thank you.
Kahylan
Hi!
Mirroring joints can be a bit unreliable at times, most of the times the problems are caused by the hierarchy above the joints or by their incoming connections.
To eliminate these problems do the following:
1) Duplicate the Leg joints
2) Unparent the duplicate (Shift+P)
3) Create a joint a world origin
4) Parent the duplicate under the new joint
5) Select the new joint and run the mirror joint command
I hope this helps!
puchis5573
Observer
Observer
I tried your advice, but it stills doing the same thing 😞
Kahylan
Hmm, could you maybe upload the file as a zipped .ma so i can have a look at it?
puchis5573
Observer
Observer
Of course, thank you very much for the help TwT!!
Here is my document.
Kahylan
Sry I was away from my machine for a bit.
I took a look at your rig. What is causing the problem is that you have "locked"  and "non-keyable displayed" channels on your joints. Follow the workflow I described in my first comment, but before you do step 5), just select every joint one by one, open the channel control in the channelbox (Edit-> Channel Control) and move all the Translate, Rotate and Scale attributes in the "Keyable" and "Non Locked" column.
This should allow you to mirror your joints properly.
I hope this helps!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
