How to properly skin mesh with overlapping geometry?
Hello people, I've got mesh that has overlapping fingers geometry. As expected, bind skin tool is not doing a good job. What should I do in that situation? I would be really grateful for any help.11.png22.png
mcw0
You can duplicate the hand and separate the fingers.  Then bind each finger to the appropriate joints.  Once you've done the individual fingers, you can then use the copy skin weights tool to transfer from your individual fingers to the fingers of the hand.  Just select the verts of each finger that corresponds to the individual fingers and copy.
Or you can try to query the normal of the problematic verts and compare the relationship to the influence joints.  Get the dot product of the normal to the vector from the joint to the vertex.  Then remove influence joints if they are out of a certain dot threshold.
Thank you, your first solution is ideal for me, I really appreciate your help!
mcw0
I'm glad my suggestion worked for you.  I thought of another possible approach.  Select the problematic vertices and use "hammer weights".
mspeer
Hi!
@Anonymous  and @mcw0
I also recommend to try Bind method "Heat Map", which should not show this problem, even if you use Bind Skin on the hand as one combined mesh, so this should give you a better starting point with one click only.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
