Maya Animation and Rigging
Welcome to Autodeskā€™s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
how to know if a constraint is default or offset in the attribute editor
5 REPLIES 5
jhonatan.chambi.capia
505 Views, 5 Replies
Hello everyone, when i work 2 objects with orient constraint (default and offset) how to know in the atribute editor, channel editor or Mel ? because is practically the same values (offset and default settings) and i can't differentiate them. some pretty basic that i can't do it until now šŸ˜ž
Thanks so much for your help, greetings from Machu Picchu - Peru
5 REPLIES 5
in reply to: jhonatan.chambi.capia
Hi
The same values (offset and default settings) and  can't differentiate them, But the Rotation Axes different.
Ref  pic attached
yeah, i don't know that!!! and when do i use offset or default in a orient or parent constraint?
Hi
Its depends upon your  way of purpose.
If u want the same  rotation axes as it is in main object, u need default settings.
if u need  just constrain , with the same position(second object)  u give offset option.
Ref Pic
For More detail about constrains  link below;
http://help.autodesk.com/view/MAYAUL/2018/ENU//?query=constrains
thank you so much sensei, all is clear for me now šŸ™‚
