Hello everyone, when i work 2 objects with orient constraint (default and offset) how to know in the atribute editor, channel editor or Mel ? because is practically the same values (offset and default settings) and i can't differentiate them. some pretty basic that i can't do it until now š
Thanks so much for your help, greetings from Machu Picchu - Peru
Hi
The same values (offset and default settings) and can't differentiate them, But the Rotation Axes different.
yeah, i don't know that!!! and when do i use offset or default in a orient or parent constraint?
Hi
Its depends upon your way of purpose.
If u want the same rotation axes as it is in main object, u need default settings.
if u need just constrain , with the same position(second object) u give offset option.
Ref Pic
For More detail about constrains link below;
http://help.autodesk.com/view/MAYAUL/2018/ENU//?query=constrains
