Message 1 of 12
I'm not even sure this is possible but...
I have a robotic arm that I want an IK on, but as you can see from the image below, the location of the tilt-joint and the twist joint is not the same (both marked by "C"), as it would be on a human arm.
So I lock the two attributes that shouldn't move for each joint, but when I test the IK it does this
As you can see, it only works for a few degrees, before it "crashes" at the top, like hitting something invisible. Same problem the other way, not to mention it is unstable. So I'd like to know: how to make IK for joints with locked rotations??(locked on two axises)
