Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Having Problems with double transforms
10 REPLIES 10
Message 1 of 11
1334 Views, 10 Replies
I am currently working on a Pokemon fanart project, and for some reason I am having trouble scaling up the model for the scene. Basically, the wing flap and teeth are attached by constraints because I cannot bind them to the skeleton without them disappearing for some reason. Then, When I scale up the joint they are constrained to, everything is fine. The moment I scale up the entire skeleton hierarchy so the entire thing gets bigger, the transforms multiply. The constrained objects are not inside the hierarchy. Any help on fixing this issue would be appreciated.
10 REPLIES 10
Message 2 of 11
Hi
I think its some Scale constrain issue.
If u share yourscene file, we will See
Message 3 of 11
Here is the file. I'm working on student version so sorry for the po
Message 4 of 11
Hi
No file here. Please check
Message 5 of 11
The site won't let me add mb files in the reply.
Message 6 of 11
osidedan
Hello! I think I might know what the issue is, but the fbx file doesn't seem to have the constraints so I'm not sure. If you could zip your maya scene file, you should be able to attach it to a post, and I can take a look.
Also, when you say the teeth and wings are disappearing when you try to bind them to the skeleton, which joints are you binding them to? We might be able to fix that problem first so you don't have to use constraints. Thanks!
Message 7 of 11
Hi
Attached Your Scene File. Now check.
Message 8 of 11
in reply to: osidedan
I bind the wings to the single joint poking out of the skeleton's back, and the teeth are bound to the base of the head.
Message 9 of 11
Thank you, but the skeleton you send has the same issue of the teeth growing out of the face when I scale up the hierarchy.
Message 10 of 11
Hi
Please  Take the mesh (Body)out of the group and scale. its works fine.
Please check
Message 11 of 11
osidedan
 I tested it out as well, and kaniveyUAWVK is correct. You will need to have all the geo outside of the group that the skeleton is in.
Delete the scale/parent constraints for the teeth groups and wings, and just bind them to the joints you mentioned above. Once that's done, you will need to change your hierarchy to be like this, so that the geo is separate from the skeleton group. After that, use the group that the skeleton is in to do your scaling:
Hope that helps, and let me know if you need more info. I'm also attaching the fixed version of the file so you can use it for reference
