Guide Animation tab for XGen is missing
I am trying to animate my hair that I created in XGen.  However, when I go under the Primitives tab in XGen, the Guide Animatoin tab that allows me to turn on "Use Animation" is not there.  I am using Maya 2016.
Replies (7)
pshwayka
Did you use the "placing and shaping guides" option when you created your description?
I think I did. How can I check that to make sure?
pshwayka
You would have had to click in various locations on the mesh to get the guides to show up at all. Do you remember doing that?
I don't think so. All I remember doing is selecting the object I wanted to apply the hair to and then creating groomable splines through XGen.
pshwayka
That's why the Guide Animation section is not showing up. You need to use the "placing and shaping guides" option when you create your description.
Is there anyway to convert what I have now to be able to animate like that, or do I have to start over?
pshwayka
I've never tried to animate groomable splines, but I think it may be possible using anim wires. See this help section.
