Graph Editor zooming Problem
r.marar
Observer
r.marar
Observer
Observer
Hello I'm facing an problem with Maya 2018.....after i delete any keyframe from the Graph editor the view in the editor zooms out which is a bit annoying...is there a way to solve that ? or the problem is just on my pc?
Kindly Find the attached picture that demonstrates the problem
Thank you.
Replies (9)
leducm
Hi @r.marar,
Thanks for your feedback !
This issue is logged as : MAYA-84698 - Framing occurs vertically after deleting keys in classic graph editor.
The workaround is to use the modern graph editor.
You can switch to the modern graph editor by changing your preferences :
Windows > Settings/Preferences > Preferences > Animation > Graph Editor > Graph Editor UI > Modern.
You should see the change after closing and reopening the graph editor.
Please let me know if this helps.
Best Regards,
Marie-Jeanne Leduc
Maya QA Analyst
r.marar
Observer
Observer
It is already on the modern graph 😞
r.marar
Observer
Observer
mspeer
Hi!
The screenshot you provided clearly shows the "Classic" Graph Editor UI and not the "Modern" one.
Please check your preferences and maybe try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
leducm
Hi @r.marar,
Thanks for your reply. It seems that the graph editor is showing the Classic UI, even though the preferences are set to Modern.
Like @mspeer mentioned, you could try to reset your Maya preferences.
Also, it would be good to check if your graphic card is on our certified hardware list and if your drivers are up to date.
Thank you for your patience and cooperation. Please let us know how it goes.
Best Regards,
Marie-Jeanne Leduc
Maya QA Analyst
r.marar
Observer
Observer
Sorry for the late reply.....i did reset the preferences and the problem is
still there...that leaves me with the graphics card, maybe it needs
updating
Hey,
Not sure if this will fix the problem. Do you have atools installed? If so, check your atools preferences to make sure 'auto frame playback' isnt selected. Fixed the same problem for me.
Cheers!
Jen
Hey,
Cheers!
Jen
OMG, THANK YOU!!! This was driving me INSANE and for the life of me I couldnt figure this out. You saved me some massive frustration! Thanks again!
