Graph Editor keeps Auto Framing (Sometimes can't mass select keyframes)
So suddenly,whenever I select keyframes in the Graph Editor, it keeps auto-framing.
In addition to that, sometimes the Graph Editor won't let me mass select keyframes.
I've turned off everything I could find related to this. (Unchecked "Auto Frame" under View in GE, Unchecked the "Sync Graph Editor Display" and "Sync Timeline Display" though Channel Box.  etc...   I know in maya 2017 there's an AutoFrame box to uncheck under Pref/Setting>>Setting>>Animation>>GraphEditor)
I even reset the maya settings by deleting the preference folder in documents. And to no avail!!
I've also noticed that this is happening throughout all the student maya versions that I have (2015, 2016, 2017)
And I haven't touched maya 2015 for months!!
Has anyone else run into this problem? It's getting a bit tedious and frustrating.
Help would be much appreciated. Thanks!
I'm having the same issue in Maya 2016. I did not have in Maya 2015. I tried to deactivate all options that could be related to keys editing on the graph editor, it didn't change a thing. This issue has been reported by many users. I'm not sure Autodesk has done anything about it...
xatori
I have exactly the same problem with Maya 15,16,17. I account his problem just a few weeks ago. Before it worked fine.
I'm using GeForce GTX 980 on my PC and Quadro K5100M on my laptop. The problem appears only at GeForce. I also tried to install the newest or some elder drivers but nothing helped. I aso tried to play with 3D settings on GeForce control panel but with no luck..
With Quadro K5100M on my laptop all versions work fine.
Can somebody help, please?
