Exporting 3ds Max rig to MAYA
Export with FBX, load to Maya. Then the orientation of the joint is messed up.I want to fix it.
I did like this:
1.Export current skin weight
2. Unbind skin
3.Freeze transform geometry and joint
4.orient joint
5.bind
6. import weight map what I exported at 1
then, skin weights are broken.
How should I fix that?
Attach the FBX created 3dsMAX.
thanks,
mspeer
Hi!
I imported the fbx file to Maya 2018.3 and can't see any problem.
What should be wrong here, how does it look for you?
the orient is not Yup . So I wanna fix that.
Yes just loaded there is no matter but if I want to fix orientation there is problem. Isn't it?
mspeer
Hi!
The orientation is Y-up here.
If you want any other orientation, just rotate your object (the skeleton).
>The orientation of each bone is different. You mean not using orient joint but rotate individually?
Thank you for your kindness.
mspeer
Hi!
This is what i get orig model + model with joints (+ one duplicated and free rotated model).
What's the problem?
hi,
Thank you for your reply.
What I want to fix is this Orient. If I freeze the transform, the skin will be broken. Of course, I can also attach controls without fixing this Orient. If I had a way to make all the orientals Y-up without breaking the skin I wanted to know that.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
