Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Error when importing FBX rig
1 REPLY 1
1170 Views, 1 Reply
I'm trying to import an .FBX rigged character into Maya for animation but I keep getting an error window that says
"The FBX plug-in has detected Non-uniform scaling values. The following nodes (or their parents,) have non-standard Maya scaling inheritance (RSrs). The plug-in will re-compute their local transforms to match their correct global transforms and re-plot the transform animation frame by frame. These nodes might have interactive behavior in Maya that differs from the source application."
When I close the window the rig no longer matches up with the model.
Is there a way to fix this?
1 REPLY 1
jmreinhart
https://knowledge.autodesk.com/support/motionbuilder/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU...
This page explans what the different scale inheritance behaviors mean. If you're the one who made the fbx you may be able to change the export settings to use the same scale inheritance as maya. Otherwise you'll need to come up with a script to fix in the scaling after you import the fbx.
