Could not add constraint or connections
odpaterson5NPU7
odpaterson5NPU7
Hello!
My team and I are running into a really bizarre and inconsistent issue: when trying to create a parent constraint on an object with keyframed attributes it gives this error:
"// Error: line 0: Could not add constraint or connections. //"
What I would expect to happen is the translate and rotate channels to turn from red to green, indicating animation curve data overridden by a constraint's data like this:
The really strange thing about this is that it's not happening for me but it is happening on my two colleagues' machines, and we're trying it on the same scenes. It's also an issue that's cropped up recently and is causing problems due to constraints being created during a python script in our pipeline.
Here's what we've tried:
  • My colleague tried making a totally fresh scene with 2 animated objects, tried constraining one to the other and hit the same error again. My attempt of the same steps succeeded in making a constraint. This suggests the constraint system is broken for them specifically and not me (!?).
  • We tried forcing Maya to create fresh default prefs by renaming the prefs folder to prefs_backup. The issue persisted.
  • We checked for incoming connections in the node editor, but they seem to just be animCurve nodes. In any case the problem doesn't happen on my machines and does happen on theirs, so the it is very unlikely to be a scene-specific one.
The Maya version we're using is Maya 2019.1 (this is a client requirement).
Any assistance one this would be much appreciated, thank you!
odpaterson5NPU7
The issue is solved! The problem lay within the settings which need to be set as follows to allow the constraints to plug into animated channels:
I would have thought fresh prefs would have reset this, but perhaps not. Anyway, posting this in case it helps someone else.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
