Change to 60 FPS persistent or delete non needed fps in Fps Enum
spaehling
spaehling
Hey everyone,
pretty simple. Iam looking for a possiblity to change the FPS on the bottom right permanent to 60 FPS. Of course i know, normally maya save an option by closing the software and reopen it. But for the FPS it doesn't work. I switches always back to standard (24 fps)
I went trough a lots of maya files looking for that ENUM of frames per second. But there are a lot files with that list.
So anyone an idea how to change it permanent to 60fps so i do not need always to switch?
Greets
Spähling
hamsterHamster
Can't you set Preferences>Settings>WorkingUnits>Time to 60fps? Saves mine 24 and 25fps, shouldn't be a problem for 60 too.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
spaehling
Sadly no. It gets always reset.
mspeer
Hi!
File > New Scene [Options] > Time
hamsterHamster
.. or simply enable Do Not Reset Working Units (in @mspeer 's mentioned solution), then it won't override Preferences' setting.
,,,_°(O__O)°_,,,
spaehling
lol i never thought about taking a look over there. Thanks a lot, it worked.
spaehling
Hey, also thank you for your reply. I keep the button in mind. Problem is solved. For some reason i never clicked on New Scene Options.
