Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Certain Vertices will not paint with the Paint Skin Weight Tool
2 REPLIES 2
meyercLQ7VZ
231 Views, 2 Replies
I'm trying to reduce the amount of vertices a joint is bound to, but some vertices will not paint for a reason I do not know. I've tried rebinding the skin to the model but with no luck. Any ideas?
2 REPLIES 2
Kahylan
in reply to: meyercLQ7VZ
Select the vertices you don't want to be affected, opend the paint skin and use the flood option with the value set to 0
stephenkmann
make your brush bigger..  I think you are just missing the points
