Hi, i am having some problems between the blendshapes that i already have created in maya and Mixamo Auto-Rig.
I will explain a bit the process that i am following to put you in the context:
I upload my character from Maya to Mixamo and i apply the auto-Rig, i download and import into Maya. I see the joints and the skin weights works good. In this point i select the mesh and i import my own blendshapes and everything still works, but when i apply here the Mixamo Auto-Control.Rig to see the controls nothing works except my blenshapes.
If i do the opposite, i import the character into Maya and then i apply the Auto-Control-Rig it works perfect, but now if i try to import the blendshapes Maya will not let me do it, and the script editor says:
Error: file: C:/Program Files/Autodesk/Maya2016.5/scripts/others/blendShapeImportShapes.mel line 22: GENERIC_WOMAN_V4 not found for the selected blend shape node. Shapes can only be imported when the base mesh names in the scene and file are the same.
i tried to change the names but still the same problem.
Do you have any idea how i could use my own blendshapes for my facial animation and Mixamo Auto-Control-Rig for the body?
Thank you very much!!
