Announcements
Blendshapes make the hands move
hi, im on a serious deadline for my uni and i dont have time to do my blendshapes again. I moved all my objects through all inputs under the skin cluster too. With my blendshapes, my hands slightly move up and go out of place when i try my blendshapes.
Is there any solution to stop other objects from moving with your face in blendshapes?
thank you.
You can use Paint Blend Shape Weight to paint the influence of the deformer as you do with Skin Weight Paints.
Right click the Geometry, go to Paint / Blend Shapes and choose your base Blend.
There under tool settings you erase the influence where is not needed, be careful to choose the right target on Paint Blend Shape Weight, this is useful for any deformer.
