Animation time slider
Hi Autodesk. Long time user and prominint animator in the making.
I have an Idea for a maya update that can better help us animators. I would like to know what you think? As you know that every time we set a keyframe, there is is a red line marked on the frame we set it on, on the time sliderbar.My idea is that for every time we set a key frame and move to select another item or controller, there will be an indicator line marked in blue to show where on the time slider bar where the last keyframe we set it on so it will be easier for animators to line their animations better.
Look down at at the time slider
heres an example I drew from sniptool. 1st picture is the right cylder keyframe in red as usual 2nd is me selecting another object that doesn't have any key frames, but showing me where I generally key framed my last selected item
pshwayka
Help->Suggest a Feature->Ideas for maya
Probably the best place to explain your idea and get votes...
