Announcements
Animation Key buttons are gone! And Mental Ray help, please help!
xbluephantomx
xbluephantomx
So I've uploaded this picture and I just noticed the autokey, set key and other Animation fancy buttons are gone from the bottom? What did I do and how do I get it back?
Also, I used to have mental ray until it disappeared on me, doesn't show up in the plug-in preferences or anything. So I tried to delete all the files I had on it from my laptop and tried to re-download it but it keeps giving me a failure notice and won't download?
Thank you for helping!
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
mujuningaiza
Autokey function when range slider is visible, so to get it back hold spacebar and LMB/MMB/RMB to east region and mouser over Range slider and other items you want, remeber mouser overing will toggle btn on/off.
Other way you can go to common menus under Display>UI Elemants and check/uncheck which you need to. Hope this might help.
Lymond Ngaiza
xbluephantomx
My program doesn't have a preference folder. I did the /Users/... etc and nothing popped up?
mujuningaiza
Preference folder is located on your hard drive under Documents/Maya/Maya***/Pref, that apply to Windows OS, about Linux/OS X try to google wher they are located
