I working on a Motion graphics Projekt with MASH and Maya 2017 up2.
The Caching as Alembic Cache file(s) was successful. Now I will load it on Trax Editor but it looks like he doesn't Support Alembic Cache only Geometry Cache (mcc /mcx). Now I try the Already Cached Alembic file to cache as Geometry Cache (mcc /mcx), but get an only Syntax error. And if I try to cache the Mash Network (select the Mesh) to Geometry same error.
Me Question is can I use the Trax Editor for the MASH Network created Stuff?
Solved by Nadja.Bueckmann. Go to Solution.
Hi @Pi-errs,
as you mentioned the Trax Editor is not working with Alembic Cache.
But it should work with Geometry Cache.
You can export MASH to Geometry cache by simply selecting a Repro mesh and going Cache > Geometry Cache > Export Cache.
If the network is an Instancer network it will need switching to Repro via MASH > Utilities > Switch MASH Geometry Type for Geometry Caching to work.
Best, Nadja
Also when exporting
geometry export > export cache
make sure you start on a frame that has particles/objects birthed else it will error that no points are present.
