A sine deformer bug?
mcw0
Advisor Advisor
mcw0
I'm using the sine deformer for basic fish swim motion.  Starting with a large wavelength and decreasing it quickly gives the impression of acceleration.  Very easy.  But then you want the fish to slow back down to a cruise and things get tricky.  But not impossible.  So I have it working.  My fish is accelerating and decelerating nicely.  So I want to do it again.  Have it do this action a little later in the time line.  With the exact same wavelength animation, I get completely different results.  My setup only works on the first iteration.  That doesn't make any sense...unless there's something wrong with the sine deformer itself.  So I checked.  I referenced in my single acceleration/deceleration animation as a check.  I shifted my reference animation to line up with the later acceleration/deceleration of my test scene.  I templated the reference so that it's easy to compare.  Here are the results.
I found an offset delta of -6 lines up the two files perfectly.  Again, both animations are identical.  I offset the time of my reference animation to line up the 2 setups.  Now I advance to the next frame.
Sorry for switching the order of the channelBox images.  Notice that everything is the same with the same delta of -6.  Yet the deformations are different.  And this is what it looks like 7 frames later.
So the logical question is, is there a slight offset in the underlying math that is causing this discrepancy?  Does the sine deformer only work within a certain offset range?  Will I have to find the magic modulus to have a repeatable animation?  UGH!!!
mcw0
Out of curiosity, I gave the modulo idea a try.  And I found a modulo of 3 works.  But only if the wavelength is not animated.  Once I unmute the animation, the discrepancy returns.
Forgot to mention that this is the first and only animation.  This isn't even the second acceleration/deceleration.  😞
