Announcements
Using wire deformer with cluster
wreliford
wreliford
I am using a wire deformer to deform a plane; however I want to animate the end point on  the curve. I can manipulate the end point but when I add a cluster to that point, everything falls apart. See attached picture.
As an alternative, I tried Deform/Point On Curve which adds a locator, but the geo doesn't conform to the curve when I move the locator. Any thoughts?
dinofiguera
I am not sure about the steps you did in your wire-cluster setup.
In the attached scene, I have created a curve, a plane, wire deformed the plane with the curve and then
added a cluster for each control vertex of the curve.
Hope this helps,
D
